[VDS] Moniteur de contrôle / montage video © (VENDU)
SoniG
Moniteur JVC TM-H150C à tube phosphore, en très bon état, peu servie, idéal pour le contrôle video, le montage et autres tâches de postproduction tel que la retouche colorimétrique.
VENDU!
Paiement : Chèque, Paypal
Remise en main propres sur Paris possible.
http://www.indof.com/_old/images/sells/JVC_TM-H150C/01.JPG
http://www.indof.com/_old/images/sells/JVC_TM-H150C/02.JPG
http://www.indof.com/_old/images/sells/JVC_TM-H150C/03.JPG
http://www.jvcpro.co.uk/jpe/en/global/product.2806.140.html
Colour system: PAL/NTSC CRT: 15" (diagonally measured), dot pitch 0.27 mm Scan Frequency: H: 15.625 kHz (PAL) / 15.625 kHz (NTSC)
V: 59.94/60 Hz Horizontal resolution: More than 750 TV lines Power requirement: 120V AC, 220-240 V AC, 50/60Hz (Power cord detachable type) Power consumption: 0.87 A Colour Temperature: 6500°K / 9300°K selectable 16:9/4:3 switchable: Yes Serial digital I/F option: IF-C21SDG / IF-C51SDG optional Y/R-Y/B-Y Component: IF-C01COMG optional RGB: IF-C01COMG optional Y/C: Y: 1.0 V (p-p), 75 ohms, negative sync
C:0.3 V (p-p), 75 ohms (PAL); 0.286 V (p-p), 75 ohms (NTSC) Composite: Input A: Composite video: 1.0 V (p-p), 75 ohms, negative sync., auto-termination, BNC x 2, bridged-out possible
Input B*: Composite video: 1.0 V (p-p), 75 ohms, negative sync., auto-termination, BNC x 2, bridged-out possible AUDIO: Connectors: RCA pin x 2 for input A and input B channels, bridged-out possible
Speaker: 8 cm round, 1 W output Under scan: Yes Pulse cross: No Blue only: Yes A/B switching: Yes Dimensions (WxHxD): 360 x 310 x 418 mm Weight: 12.2 kg
