Version VEGAS PRO 8 b
Salut à tous,
J'ai voulu mettre à jour ma version a par la b, évidemment, et là big problème, tous les projets en cours ne retrouvent plus les chemins des fichiers, pagaille, plantages, importations de fichiers devenant impossible, etc..
En remettant la version ''a'' tout est revenu dans l'ordre.. ??
Quelqu'un a connu ce problème ?
Merci pour les réponses.
C’est la première fois que j’entends parler de problème de la sorte.
Commence par faire une réinstallation propre comme indiquée par Sony (voir ci dessous).
Si cela ne règle rien, je pense que tu es bon pour contacter le support technique.
Therefore, I'm going to suggest that you un-install all of your Sony Media Software and older Sonic Foundry software. Do this by going to Start > Control Panel > Add or Remove Programs.
Once un-installed, delete the following folders:
C:\Program Files\Sonic Foundry
C:\Program Files\Sonic Foundry Setup
C:\Program Files\Sony (Do not delete this entire folder if you have other Sony applications installed such as Sonic Stage, Everquest, Star Wars Galaxies, etc. If that is the case then only delete the folder for the Sony Media Software application you are using as well as the Shared Plug-Ins folder.)
C:\Program Files\Sony Setup
Once un-installed, click over to your Windows Registry Editor (Start -> Run -> regedt32).
WARNING: The Registry is a very sensitive area to work in. If you are not comfortable with advanced configuration and system changes, ask an administrator to help you with this.
Once in there, delete the following registry entries:
HKEY_CURRENT_USER\Software\Sonic Foundry
HKEY_CURRENT_USER\Software\Sony Media Software
HKEY_LOCAL_MACHINE\SOFTWARE\Sonic Foundry
HKEY_LOCAL_MACHINE\SOFTWARE\Sony Media Software
Next, disable everything under Startup in MSCONFIG. Do this by going to Start>Run 'MSCONFIG' - Startup Tab, Click Disable All, Click Apply, Click Close, Click Restart Now.
After the computer is restarted, press Ctrl+Alt+Del at the same time and you will see a list of the programs currently running (some users will have to hit the "Task Manager" button). Move over to the Processes Tab and click the "Image Name" heading at the top left of this window to view these items in alphabetical order. Close everything showing on that list except for the items listed below. To end a process, highlight it and click the End Process button at the bottom of the window.
End every process except for:
alg.exe
ccmexec.exe
csrss.exe
explorer.exe
lsass.exe
MsPMSPSv.exe
services.exe
smss.exe
spoolsv.exe
svchost.exe (there may be more than one of these, you can leave them all running)
System Idle Process
System
taskmgr.exe
winlogon.exe
wmiprvse.exe
You may have other Users logged into the system and displayed on this list, but make sure you log them off and close down their processes as well.
This is a good opportunity to remind you to temporarily disable your system's anti-virus software. If running in the background while installing the application, it can be difficult for the system to update registry values needed to help the program run smooth.
After removing all of the previous items, just download and re-install from the latest updated versions of software from this link - http://mediasoftware.sonypictures.com/down...ep1.asp?CatID=2. These files will be the latest full installers for our software.
    • Bonjour, Tu as deux solutions pour "archiver" ton projet (deux au moins... il y en a peut être d'autres que je ne connais pas....).   1-le plus simple et le plus complet, est de se mettre sur la bibliothèque de projet de faire un clic droit sur le projet à conserver puis de choisir "exporter l'archive du projet" et tu choisis l'emplacement de cette archive. Ainsi tu auras dans un dossier le fichier montage (qui est fichier "dra") et tous les clips (vidéos, sons musiques, voix, effets.... ) qui sont dans ta bibliothèque de médias, y compris ceux que tu n'as pas utilisés sur la TL.   2-Mais si tu veux conserver le montage et uniquement les clips qui ont été utilisés, il te faut archiver en deux temps: Pour cela tu vas opérer non pas sur la bibliothèque de projet, mais sur le projet ouvert. Dans un premier temps, tu vas archiver les médias que tu as utilisés dans ton montage: Dans le menu fichier tu vas à "gestion des médias", tu localises un dossier d'archive et tu choisis "projet entier", "copier" et tu coches "utiliser les médias" si tu veux strictement la portion de médias utilisée ou mieux medias et trim ce qui te permets de copier la partie de média utilisée avec quelques images avant et après. Puis ensuite tu exportes le fichier projet en faisant fichier "exporter un projet " et tu auras alors un fichier drp   Perso, en général lorsque j'ai fini un projet mais que je suis susceptible de devoir y revenir et l'adapter, je fais d'abord un archivage de projet à partir de la bibliothèque de projet (un drp), puis un an ou deux après quand je suis sûre de ne plus avoir à retoucher mon montage et que je veux simplement l'archiver en allégeant le contenu de mon disque d'archive, je fais un "drp".   Un dernier point, cet archivage ne nettoie pas ton ordi pour autant et je te conseille dans les deux cas, d'immédiatement supprimer les clips d'origine (sinon tu les auras deux fois sur ton ordi) et surtout de supprimer les fichiers caches qui sont des fichier lourds et qu'ensuite on oublie de supprimer...   En espérant que cela t'aidera et en te souhaitant une bonne année pleine de vidéos et montages passionnants,
