Transmitteur son wireless Audio Technica ATW-R100
rafaelm
A Vendre Transmitteur & Receveur Audio Technica ATW-R100
Frequence: 728.125-740.500 MHz
Comme neuf. Case en métal, pas comme les nouveaux en plastique.
Gratuit: pochette pour attaché a sa ceinture.
J'habites en Californie ou mes passions de videaste se sont calmées... et remis au graphisme. J'ai honte de dire que je ne l'ai utilisé qu'une seule fois pour moins d'une heure! :eusa_think:
Anyway, mon amie Amélie habite a Paris et s'occupe de cette vente pour moi.
J'ai les factures originales a disposition egalement.
Prix de vente: 250 euros.
Contact: Rafael a Los Angeles, rafael@rafaelmacho.com
Amélie, Paris: amelie.gamet@free.fr
Ci-dessous quelques details techniques en anglais:
Audio-Technica ATW Series - Camera Mountable UHF Diversity Lavalier System with ATWT101X Transmitter, ATWR100X Receiver (Carrier Frequencies) 656.125 to 668.500 MHz).
The Audio Technica ATW Series wireless microphones provide a complete camera mountable UHF wireless microphone system including camera mountable receiver, body-pack transmitter and lavalier microphone. The system features 100 user selectable, PLL-synthesized frequencies providing an abundance of alternative frequencies when needed.
The ATW-R100x receiver is completely portable and features a true diversity design. True diversity is represented with dual antennas. Each antenna feeds a separate internal receiver on the same frequency, and the dual internal receivers are at a constant battle for the strongest possible reception. The receiver is powered via 2 internal 9 Volt batteries or external 12V DC.
The ATW-T101x body-pack transmitter also features 100 user selectable UHF frequencies. The input is a standard TB5M connection with provisions for both, microphones and line-level devices. The transmitter is powered via 9 Volt battery and has an Off/Standby/On switch, input level control, battery condition indicator and channel selection switches.
• Separate Operating Channels
The ATW series is manufactured in 2 versions, all "x" models operate on channels 67 through 69 providing further frequency selection.
• 100 Switchable Frequencies
The U100 series components operate on 100 user selectable PLL-synthesized frequencies. Frequency agile transmitter and receiver deliver an abundance of alternative frequencies when needed.
• Diversity Receiver
The ATW-R100x features dual internal receivers tuned to the same frequency. The result is 2 receivers constantly relaying between each-other, searching for the strongest possible reception.
• Flexible Transmitter
The durable, lightweight ATW-T101x body-pack transmitter feature a TB5M input connector with provisions for both mic-level and line-level devices.
• Rugged Construction
All metal, roadworthy construction ensures maximum performance and durability in any environment.
Original source:
Audio-Technica | ATW Series - UHF Lavalier System (x) | ATWU101X
    • JLB21: "Pourquoi 'se voulait' ? Il n'y a pas plus exhaustif en termes de montage vidéo que DVR, c'est incontestable. D'où sa complexité…" -> Bon d'accord. C'est une manière de dire que je suis très frustré de ne pas pouvoir enregistré ma voix off directement sur DaVinci en cliquant sur le micro. Alors que la fonction existe sur bel et bien sur DaVinci. Et pour l'instant je ne sais pas ce qui désamorce cette fonction. DaVinci n'est peut-être pas du tout en cause. C'est peut être un bidule-machin qui déconne au plus profond de mon Mac, ou bien une case à décocher dans le sous-menu d'un sous-menu. Charlie: Oui c'est une solution de "bricolage". Enregistrer une voix off puis la découper en 100 morceaux pour la recoller en un autre puzzle ...C'est toujours une solution. Mais pour moi, l'idéal c'est de faite un prise de vidéo propre, et une prise de son propre. Le but n'est pas de les découper et bricoler dans tous les sens par la suite. Bien sur on peut toujours bricoler/découper,  parce qu'à ce moment là un chien a aboyé au loin ou un avion est passé dans le ciel. Mais l'idéal c'est de bricoler le moins possible. En générale je fais 3 fois la même prise de vidéo/son de la même scène. Histoire de choisir la meilleure, et de pouvoir bricoler si nécéssaire en piquant sur l'une ou l'autre. Mais "bricoler" ce n'est vraiment pas ma direction première, c'est la dernière solution de sauvetage. Non seulement c'est beaucoup plus de travail au montage, mais en plus il y a toujours un petit quelque chose de faux en arrière plan. Par exemple de ce joli papillon posé par hasard sur la fontaine en pierre, mais qui a subitement disparue sur la scène suivante sans qu'on le voie s'envoler (parce que le caméraman s'est pris les pris dans le câbles et a chuter en faisant fuir le papillon). Parfois un de mes chat passe dans la prise de vue, c'est totalement involontaire, mais je trouve que ça apporte un plus (notamment parcequ'il donne l'échelle des élément en scène), et si le chat est là, il ne peut pas disparaitre par magie lors du changement de scène. Ou alors c'est la lumière qui change: on avait grand soleil, puis un nuage passe et les scène suivantes seront toutes dans l'ombre, au montage la lumière ne corresponde carrément pas, etc... Bref: bricoler, oui, c'est aussi ça que nous permet la technologie. Mais bricoler le moins possible pour avoir le plus d'authenticité possible. La dessus, je part en vacance (comme beaucoup :D). Alors je ne répondrais plus à ce poste que je met en pause pour quelque temps. J'y reviendrais après les vacances. Je vous souhaite de passer de bons moments chaleureux pendant ces fêtes avec vos proches. Merci à vous, Bart
