Video wakeboard
Cedio
Merci à toi labrot de ton avis
Je doit régler se problème de surexposition (video trop blanche en gros sa veut dire ??)
Je vai essayer d améliorer mes plans de vue et être plus precit
C est pas facile avec c est joujou on n'a la pression quand il sont au dessus de l eau !!!!
    • Voici les fonctionnalités ajoutées ou mises à jour de la nouvelle version de DaVinci Resolve 20 !   Une sacrée brochette de caractéristiques, avec pour dénominateur commun l'IA... Je crois qu'on peut parler de "mise à niveau".       Key New Features Improved keyframing with dedicated curve view and timeline drawer. Voice over tool with record and monitor options. Import Blackmagic Cloud Shared folders to media pool. AI IntelliScript creates timelines with a user provided script. AI Magic Mask v2 with paint brush. AI Dialogue Matcher matches clip tone, level and reverberance. AI Audio Assistant automatically creates a finished mix. AI IntelliCut removes silences and checkerboards speakers. Deep image compositing toolset.   Cut Page Voice over palette with cue, voice tools and teleprompter. Ripple trimming of audio now available on secondary tracks. Replay multi views now show previously used camera angles. Tapping time buttons allows camera buttons to preroll replays. Auto resync media bins now supports stills and sequences. Live overwrite now supports edit keys and search dial. Mouse drag to live overwrite multi source and sync bin. Trim with safe edit avoids overwriting adjacent clips. Media pool metadata palette allows quick review of selected clips. Ability to copy, paste and remove attributes from timeline clips. Support for a dynamic trimming mode using JKL controls. Full featured audio mixer. Mini timeline now includes a context menu.   Edit Page Voice over tool with record and monitor options. AI Multicam SmartSwitch for automatic angle switching. AI VoiceConvert with built-in and user trainable models. Support for source tape. Ability to view and edit timelines in the source viewer. Multicam creation now supports a reference audio track. Opening compound clip from timeline matches playhead position. Access timeline settings from timeline tab context menu. User preference to wrap around 24h timecode.   Cut and Edit Page Improved keyframing with dedicated curve view and timeline drawer. Import Blackmagic Cloud Shared folders to media pool. AI IntelliScript creates timelines with a user provided script. AI Dialogue Matcher matches clip tone, level and reverberance. AI Music Editor automatically edits music to desired length. AI animated subtitles highlights or animates spoken words. AI SuperScale now includes 3x and 4x enhanced upscaling. AI Detect Music Beats displays and allows beat snapping. New optimized UI layouts option for vertical videos. Custom grid for sorting and organizing of media pool thumbnails. Text+ paragraph, line wrapping and bounding tools. MultiText tool with layers and easy transform, clip and wrap controls. Subtitle tracks now support Fusion templates for styling. Selectively sync media originals with proxy only cloud sync. Imported PSDs can now be split into individual layers. Support for Alert Red viewer background mode. Transcription engine now offers extended language support. Smooth Cut now supports AI Speed Warp. Export audio transcriptions with speaker and timecode. Export transcriptions with improved phrase and sentence breaks.   Fusion Page Deep image compositing toolset. Multi layer pipelining for OpenEXR, PSD and stereoscopic 3D. Vector warping toolset for image patching and cleanup. Support for 180 VR. 3D Scene Dome Light. Support for native Cryptomatte workflows. View color page grade in media out node. Faster GPU based pano map and spherical stabilizer tools. Ability to search tool based on effects category. User selectable starting frames for compositions.   Color Page AI Magic Mask v2 with paint brush. AI Resolve FX Depth Map v2. Chroma Color Warper grading. Resolve FX Warper features new spline warp controls. Open Color IO supported as Resolve FX. New optimized UI layouts option for vertical video. Display viewer overlays for remote monitoring. Stream and monitor H.265 4:2:2 on supported hardware. Support for Samsung Log. Support for ACES 2.0. Ability to generate HDR light level PDF reports. LUTs and colorspaces can now be modified in multi-user projects. Node layer controls in the advanced panel. Lift, gamma, gain Micro Panel sensitivity improvements.   Fairlight Page AI Audio Assistant automatically creates a finished mix. AI IntelliCut to remove silences. AI IntelliCut to checkerboard dialogue by speaker. AI IntelliCut to generate ADR Cues using transcription speaker info. Clip EQ now features 6 bands. EQ and Level Matcher processes match tone and clip levels. EQ and Gain now also available as Fairlight FX plugins. Fairlight Chain FX to create and restore frequently chained plugins. Drag header color to move tracks and busses in the timeline. Automation now supports per channel mode switching. Trim automation now remains active through a mix pass. Improved view presets store multiple parameters.   Codecs Apple ProRes encode support on Windows and Linux. Encode MV-HEVC without spatial video metadata. MV-HEVC encode support on Nvidia systems. Support for side by side stereo 3D media decode. Side by side display mode for stereo 3D clips in source viewer. Editable spatial video metadata properties in inspector. GPU accelerated H.265 4:2:2 encodes on supported Nvidia systems. GPU accelerated H.265 4:2:2 decodes on supported Nvidia systems. Support for growing TS, MTS and M2TS files as media streams. Support interlaced rendering for frame based formats. HT JPEG 2000 decode support for EXR. Quick Export dialog with custom user preset listings and list view. Ability to assign custom icons to user presets in deliver page. Support for Sony Burano 2.0. Support for RED SDK 8.6. Support for audio normalization for Dropbox presets. Improved PNG support with HDR and SDR signaling.   LIRE LA NEWS COMPLETE
